Thanks for the reply.
I'll cut the filament in 1 kg pieces and modify the profile to work with the material station.
maximum weight for spools in material station
UlrichC-DE 114
Hello
In the material station you lose approx. 2.14m per cut.
At 3Kg, that's two additional cuts (4.28m).
Just as a hint 🙂
Best regards
UlrichC-DE 114
Before I forget.
I also do the rewinding sometimes.
With this: https://www.youmagine.com/designs/rewind-adapter-for-ultimaker-spools
Many greetings
Dim3nsioneer 558
The 3kg Ultrafuse 316L spools should be put on an external spool holder based on ball bearing, otherwise you get an underextrusion due to too high resistance when turning (e.g. on the UM spool holder). So it's not ideal to put it into the Material Station.
Also, the material profile from BASF is not compatible with the Material Station.
