Hello,
Yes I already have the 4.9.1 installed, but still the same issue. It needs to prime a looot if it's going to be ready for the next spool basically, hard for me to know how much as I'm never present during spools changes.
UlrichC-DE 109
Hello
In the early days I had also pursued such projects with the material station.
Thank you for the picture. It gives you the idea that maybe the Z-axis is dirty.
But it could also be due to the printer's firmware.
The current firmware 6.4 only makes a clean deprime on -abort- with Ultimaker filament. So if you work with generic Filamant, it can theoretically come to such effects. The next version should fix this.
Now, of course, I don't know if you are working with generic filament. And I don't know if -abort- off is the same as changing the material. Just a suspicion.
Many greetings
Hi Ulrich,
I'm using the latest stable firmware update and also using Ultimaker PLA filament if that helps.
UlrichC-DE 109
If you have Cura 4.9 installed, you should change to 4.9.1. With 4.9 I also had problems with the prime blob. It extrudes too little at the beginning. I don't lose any layers at the moment, although I mainly work with 0.8 nozzles.
Many greetings
