Rounded corner in a shell part
2io
Posted · Rounded corner in a shell part
Hello,
I would like to get the perfect settings for this shell part and I cannot find a solution.
I installed Cura 4.9.1 from 4.8.0 and saw no improvement.
I see an improvement with KISSlicer64 v1.6.3 - this is a standalone software with only 2.6Mb .
Should I attach also the stl Part?
Cura, 0.3mm Layer 124
* position 1 and 2: the seam should run continuously.
171986596_20210621220934-CE3PRO_FrontDrawerSupportradius-UltimakerCura3mm680.thumb.png.2cda73b058b6c3507988a483cb0ef51d.png
Cura, 0.3mm Layer 680
* the green thick lines pointed by blue arrows are actually double lines. The strange thing is the empty space on the corner.
632567672_20210621220759-CE3PRO_FrontDrawerSupportradius-UltimakerCura3mm680.thumb.png.f9d4775ae7a7696da7854ca1c0d15ca4.png
The KISSlicer64 make it perfect on the corners, but has another places where it has minuses.
1436780871_20210622072407-KISSlicerSettings3mmz5218.thumb.png.0b2e4346edaabbe991786a083c36941b.png
Cura, 0.4mm Layer 43
* almost perfect (the interior green line on the corner should have also a radius)
532169321_20210621222108-CE3PRO_FrontDrawerSupportradius-UltimakerCura4mm43.thumb.png.1536a593cbab30b69a4a1d04111f141f.png
KISSlicer64:
* on corners is perfect
447883717_20210622072002-KISSlicerSettings4mmz5219.thumb.png.a34eb2b8a91a7e1affdfaa0874a47623.png
Cura, 0.6mm Layer 143
* the rounded corners are perfect, but the blue marked corner has a small yellow extra line - I suppose this is not needed - that area could be simply be filled by running the yellow lines straight - but there Cura makes round yellow lines.
16272881_20210621223512-CE3PRO_FrontDrawerSupportradius-UltimakerCura6mm143.thumb.png.74801d5b58bf98074ba3c1ebea6e5c88.png
KISSlicer64 make it perfect - other places are problematic (marked by blue arrow):
1364481499_20210622072150-KISSlicerSettings6mmz30032.thumb.png.785f988c851927895b9109ba26fa28c8.png
Also for Cura 0.6mm on layer 20 and 21 I see short lines - these are not needed:
Layer 20
1442031686_20210621223758-CE3PRO_FrontDrawerSupportradius-UltimakerCura6mm20.thumb.png.530a0f6d7cf41222ab2e0ea012965e45.png
Layer 20 detail
822368505_20210621223821-CE3PRO_FrontDrawerSupportradius-UltimakerCura6mm20detail.thumb.png.21c54d8a2b759a45c5e4ca3a56bf8475.png
Layer 21 detail
764140866_20210621223838-CE3PRO_FrontDrawerSupportradius-UltimakerCura6mm21detail.thumb.png.d3028e60ec19707712a363dd5400d5c9.png
Layer 20 detail
1500291779_20210621223902-CE3PRO_FrontDrawerSupportradius-UltimakerCura6mm20detail.thumb.png.95f6a324a66b4c20d686760110eccdc9.png
Layer 21 detail:
943211736_20210621223918-CE3PRO_FrontDrawerSupportradius-UltimakerCura6mm21detail.thumb.png.4472762ba2f4185e32baf4c6d9f1e1d5.png
Kind regard,
Ionut
    Thank you so much. It seams perfect, at least for this part. I will reply if something goes wrong at print time.
    As info: Nozzle 0,3mm
    265629037_20210622175317-CE3PRO_FrontDrawerSupportradius-UltimakerCura3mmlayer44.thumb.png.c242ea0cff668d56a1e023a42e0a06fc.png
    Nozzle 0,4mm
    1117617532_20210622175054-CE3PRO_FrontDrawerSupportradius-UltimakerCura4mmlayer60.thumb.png.6c09e99d9f582840c24b33c945af1007.png
    Nozzle 0,6mm
    1621705020_20210622175450-CE3PRO_FrontDrawerSupportradius-UltimakerCura6mmlayer43.thumb.png.cbbbbab96bbcaa6a307410848dacd98a.png
    Thank you and kind regards
    Ionut
        • 27 replies
