I put it back in and the bowden tube will lock in place but if it is in place the lift switch won't lift the extruder #2 and lock in the forward position. There may be a small tube that goes under the keeper but I can't find a parts diagram to show how it is assembled. Extruder #1 looks as though it has a small tube under the keeper that isn't on #2.
Smithy 1,145
Have you tried to remove the collet and put it back, maybe that helps?
If not here is a video of disassembling the print head, maybe it helps to find the problem.
