You could try to heat up the core, but open the front door of the head that the fan is not cooling anymore the heat break. But be careful otherwise you mess up the upper part of the core with filament and it. would be hard to get it out.
Maybe a better solution is to cut the filament from outside with a cutter or something like that. I had the same problem some months ago and I was able to cut the filament exactly above the print core.
If nothing helps, you can only open the print head itself.
Smithy 1,146
