The great @ahoeben created a plugin for exactly what you want: https://marketplace.ultimaker.com/app/cura/plugins/fieldofview/MaterialSettingsPlugin
If you like his work, don't forget to donate something to him. He's not getting paid for making these plugins, so if you can spare something, i'm sure he'd appreciate it.
Edited by nallath-
1
qwertymodo 0
Poking around in the config files, it looks like material properties are stored in materials\*.xml.fdm_material, and setting key names use spaces, whereas *.def.json files and *.inst.cfg files use underscores. It also appears that the *.def.json and *.inst.cfg files prepend "material_" to the material properties, so if I want to move the key "material_linear_advance_factor" from its current place in my *.inst.cfg (quality settings) files, it should go into *.xml.fdm_material as <setting key="linear advance factor"> is that right?
