STL file scales down in Ultimaker Cura 4.10 (all dimm are 10 times smaller)
Posted
· STL file scales down in Ultimaker Cura 4.10 (all dimm are 10 times smaller)
You were right. Thank you.
I am working in mm as well.
What happen. The new Inventor 2022 was installed and all the settings went to a different default point.
When I exported the file into STL format, there was an option where I had to choose mm instead cm.
This is how I fix it.
Thank you again.
IRobertI 521
Cura works in millimeters, are you sure you didn't accidentally export at the wrong scale from your CAD program?
SCalin 0
Thank you again.
