Posted · ArcWelder update
I have been using CURA 4.10 for a while, but in the last couple of days there was an update for the ArcWelder plugin.  I checked github and there are no program updates, so I am curious what the update was.
Thanks.
    • Add firmware compensation toggle setting
    • Add allow dynamic precision setting
    • Remove incorrect minimum/maximum values for resolution
    • Align setting names and defaults with ArcWelderLib
    • Update ArcWelder executables to 1.1.1
    • Add documentation to readme
    No, nothing in particular.  To be honest, most of it would probably be soooo far above my head anyway.  I was mostly just curious since FormerLurker's github page doesn't have any updated release since February.
    That release from back in februari did not add or change anything for files sliced with Cura, so I never got round to making a new release with just that version update in it (because it would not change anything). Instead I waited until I had some more time to fix bugs/issues on the Cura integration side of it. At the same time I made sure to have the plugin use the same terminology and order of settings as the official documentation. It is not a big update.
