wifi connect doesn't work
AndreaTrevisani
Posted · wifi connect doesn't work
cura 4.10 does not find my 3d printer twotrees sapphire pro, the wifi module is mks robin wifi v1.1, it is connect and detectable on the net, ping respond and it is configurable with browser at ip address 192.168.1.37.
Do yuo can help me ?
Thank you for all
Andrea Italy
    That is not entirely accurate.
    With plugins you can print to other printers too, but this may not be well integrated into the "Add printer" dialog. You may first have to add the printer as a non-networked printer, and then do additional steps to configure it to print via the network through the appropriate plugin.
