my 3D printer is 350x350x400 . my model is 330x330x24 and it prints it half the size
Posted
(edited)
· my 3D printer is 350x350x400 . my model is 330x330x24 and it prints it half the size
If the model is 330 x 330 on the build plate in Cura then that is the size it will slice. To my knowledge there is no further scaling of a model within Cura to generate the gcode. Do you happen to be using Octoprint? Do you have a post-processing plugin active?
If you open the gcode file with a text editor, at the beginning of the file Cura inserts comments on the model size plus the room taken up by a skirt/brim/raft. If you subtract MinX from MaxX and MinY from MaxY you will get the amount of floor space that the model takes up.
This is from a 25 x 25 cube sliced with no skirt or brim:
Because there is no skirt or brim: MaxX - MinX + LineWidth = ModelSize so 127.3 - 102.7 = 24.6 + .4 line width = 25. If it was sliced with a 10mm brim the math would come out to 45.
Post-processing a Gcode file to mirror it is pretty easy, but scaling a gcode file is not.
Edited by GregValiant
GregValiant 1,364
;MINX:102.7
;MINY:102.7
;MINZ:0.2
;MAXX:127.3
;MAXY:127.3
;MAXZ:25
