I'm having the EXACT same problem.
Brand new Vyper. Updated firmware for both motherboard and screen. Auto-levelling works perfectly.
I'm not sure where you're seeing a "set home offset" option Greg. I can't find anything like that on the LCD at all.
What am I missing?
GregValiant 1,318
Pick one of the Anycubic machines that is the closest match to your machine in "Settings / Printer / Add Printer". Select "Add a non-networked printer" and scroll down to the Anycubic machines. The i3 Mega (EDIT per ZDOG90210: not the "X" model) seems like a good choice.
On the right side of that dialog you can change the Printer Name to whatever you prefer then select "Add".
The next dialog contains the machine settings. You have a different size build plate than the Mega X so you need to change the numbers to X(width) = 245, Y(depth) = 245, Z(height) = 260. Make sure "Origin at Center" is NOT checked.
IF your build plate actually measures 245 x 245 you may want to enter a smaller number in Cura so there is a safety border around the build surface. That will insure that prints are always on the build surface and not hanging off the edge.
If that is the case then I would enter 240 x 240 x 260 in Cura then on the printer select Auto-Home. Using the controls on the LCD move the print head to a point 2.5mm in from the left edge of the build surface and 2.5mm in from the front edge of the build surface at a Z = 0. On the LCD select "set home offset" and then "save settings". The build plate in Cura will be synced to your real build plate on the printer.
The Anycubic site has Cura 4.2.1 for download. I looked at it but it doesn't have a specific definition file for your printer.
