Welcome, Cez! As Valcrow says... if you rotate the bed 180 degrees it will line up better with the center - but it doesn't really matter either way. Most of your test pattern looks pretty good - fairly evenly laid down. The bottom right is a bit questionable, but its probably because you went off the edge of the tape. (I strongly recommend that you get some wider tape, btw - makes it much easier to replace the tape, gives a better finish on the bottom of prints, and helps to resist warping forces as the prints cool which might otherwise pull the tape off the bed, and give prints a curved bottom.
The alignment probably isn't a big deal - may be that the bed isn't quite centered on its sprung screws quite right, or something in the frame is slightly twisted. But it doesn't look bad, and all that really matters is that your prints come out right. If the corners of the test square are true right angles - and square prints come out square - then its nothing to worry about. (The top of my UM2 is massively off-square, and I'm getting stunning prints with that).
valcrow 144
I'm pretty sure we've all done this at least once... but your platform just needs to be rotated 180 degrees. Big holes on the keyhole on the right.
As long as it's level though, you should be fine, unless you're printing really big objects.
The print looks like it's a tad hot. I would lower the temperature a bit and maybe slow it down a touch too. Learn to use the full settings, things start improving dramatically.
