I'm using an Ender 3 Pro with Cura v4.8.0
GregValiant 956
My printer is an Ender 3 Pro. It's odd that you can't make the changes. I wonder if it is a problem with the install. Did this just start or has it been going on a while? I'm using 4.10 now but I never noticed a problem with 4.8 or 4.9.
I own one printer but I have 10 or 12 installed in Cura for troubleshooting. Occasionally I'll notice oddities when changing printers. You can try installing another printer in Cura and it will become the active printer. Switch back to your printer and see if things straighten out.
Do you have the “Spiralize outer contour” setting turned on? In that case there is no infill, no matter what pattern or density you select.
3 hours ago, GregValiant said:going on a while?
That's tough for me to say. I haven't used any older versions of Cura to compare it to.
"Spiralize outer contour" is off.
It looks like that is a bottom layer, which does not have infill.
GregValiant 956
Yeah, that's the bottom skin. It's "Top/Bottom Line Directions" that you want. Since you have the part at about 45° to the bed - try [0,90] for line directions.
That explains it. Thanks for the help!
GregValiant 956
What printer is that and what version of Cura are you using?
