I have tried increasing the wall line count and the problem seems to be resolved.
However, I don't want to print the walls and was wondering if there's an infill setting in Cura that could help resolve the issue as well.
Why wouldn't you want to print the walls?
Its just a requirement of my research.
You could play with the infill overlap setting. By default it's not on zero to ensure that the walls and the infill stick together well.
nallath 1,101
You're changing a lot of settings to values that you shouldn't use.
Have you tried printing the object without changing settings? At the very least set the wall line count to 2 and top/bottom layers to 5.
