Posted (edited) · Materials no longer has Flow Rate?
I'm running 4.10 Enterprise and we use it here at work for the Ultimaker S5's and Modix 120's
At home I have regular Cura
One thing I have noticed is that as I calibrate flow rates for materials at home, I have a FLOW setting in the Material Manager for each material I use.
I do not see a FLOW field in the Cura 4.10 Enterprise Material Manager
Any reason?
Thank you!
Edited by LePaul
    Posted · Materials no longer has Flow Rate?
    I am not 100% sure, but I think the FLOW field is something which comes with the material settings plugin. So I guess you have installed it at home.
    For Cura Enterprise you can only install a handful plugins which are approved, not everything is available for the Enterprise version.
