GregValiant 956
Or you can add your printer as a Creality CR-10 "base" model. On the right side of the screen you can change the name to whatever you want.
After adding the printer go to Manage Printers / Machine Settings and double check the size of the build plate. It might be listed as slightly smaller in the X and Y than what you physically measure but that is because Creality leaves a safety margin around the periphery to insure prints are actually on the bed and never hang off the edge.
As far as Cura is concerned, all the CR-10 definitions are the same except for the build plate size. I know there are some other variations but the gcode generated for all of them is the same.
I would think that Creality will provide a definition file for the V3 for the next release of Cura.
SandervG 1,518
Hi, these resources might be helpful to you! Good luck!
