25 minutes ago, obewan said:playing about with line width and number of lines almost sorts it.
Using the cura arachne engine completely sorts it.
Thanks for the prompt reply. However; could you give me some pointers what "number of lines" you have been playing with? Wall thickness? Set to what?
And, similarly; how to start the "arachne engine"? Should I select something? Although I use an UMO I am still pretty much using the standard settings. I am not that adventurous. 😉
Finally; would you agree that this is an imperfection in Cura? I think it should be so that under the whole 0,6mm of wall there should be a floor, level with the top of the middle hole, exactly how it IS done between the lower and middle ring. Why does it sometimes work okay, and sometimes not. That seems a bug or hidden feature at least.
Thanks for some pointers.
Cube
obewan 36
