Well I have that installed and STILL can't see it. When I look at installed plugins it does say something about changes need to be made in the sidebar over-ride???
Click on or near the small pencil in the bar along the top of the window.
Generally speaking, all the sections on that top bar "do something" when clicked.
GregValiant 1,330
It isn't loaded at installation. Go to MarketPlace (upper right) and then Plugins / Community Plugins and scroll down to Printer Settings and install it.
Mostly they are guides for other settings in Cura. For example, if you have your max Z feedrate at 10 in Printer Settings and try to set the Zhop speed to 20 you will get a warning and Cura won't slice.
I think the only thing it's required for are multi extruders that share the heater and nozzle (like the 2-in-1-out hot ends).
