Check the Initial Layer Horizontal Expansion. Make sure it is set to "0". It's possible that Horizontal Hole Expansion is a problem but if the thin features show up on subsequent layers then the problem may well be the Initial Layer Horizontal Expansion. I don't think there should be difference between Skirt and Brim though. Are you using two different profiles with one set for skirt and the other for brim?
Posted
(edited)
· Cura 4.10 first-layer problem with skirt
Ups, I forgot to comment, sorry
Yes, it was Initial Layer Horizontal Expansion and no, the profiles are identical except for Build Plate Adhesion Type.
Edited by esopalumpa BI
GregValiant 1,351
