Hi @UlrichC-DE,
Nice to hear your opinion on Ultimaker Nylon.
To clarify, Ultimaker Nylon is a PA6/66 based material. Typically this is a bit more flexible than PA6 (3 GPA modulus, but stiffer as a PA12 (1 GPA modulus). PA6/66 typically has a modulus of 2 GPA (literally in between).
Added benefit of Ultimaker Nylon is the reduced moisture absorption speed, so it takes longer before it adsorbes moisture compared to other PA6/66's.
In terms of adhesion and warping, I might be able to give you some tips.
Warping for Nylons is mostly caused by crystallization, so avoiding crystallization is key to reduce warping. Typically this means to reduce the build plate temperature (instead of increasing it for amorphous materials like ABS and PC).
The standard profile setting uses a build plate temperature of 70C, which is above the Tg of the material (50C). What actually happens it that the bottom layers will crystallize and lead to a stronger part.
Another option, is to set the build plate temperature to 30-40C, which is below the Tg of the material, and less crystallization and thus warping occurs. Try this out, this works quite well if you have warping.
However, the 'downside' of this is that you get a part of amorphous PA6/66. Typically this means a modulus of about 1 GPa (so it's more flexible) and a part which does not have high temperature stability (50C)
If you need the added stiffness and heat resistance, you might 'anneal' (crystallize) your printed part at 70C for 1 hour per mm thickness. It's important to have a good temperature control in your oven (typically convection oven).
Hope this is helpful, let us know if you've tried any of these tips.
1
UlrichC-DE 122
The PA material from Ultimaker is comparatively harder and more dimensionally stable than PA (natural).
Since I have not yet found a designation for a more precise material definition, it ranks somewhere around PA6 for me.
Otherwise I also print PA material from BASF and Taulman or have PA12 parts laser-sintered to order. Hence the approximate material estimate.
The Ultimaker PA is unusually resistant to wear. Also against carbide.
My sure way to get a saw blade dull in a short time is, "Saw a printed product out of Ultimaker PA."
I only print the material on the UM pro bundle. PA was the reason for me to use a bundle.
The material station helps to keep the material dry.
The exchangeable print heads help to get through without clogged print heads.
(Because I have a set of 0.4 and 0.8 print heads in the drawer for the Ultimaker PA.
At first it was just a theory but it has now been confirmed.
If I always print the same material with the same print head, I have to clean less often.
Other print heads with which I print mixed ABS, TPU and PLA, for example, have to be cleaned more often).
The material warps, unfortunately. This is common for PA, unless it contains additives of CF.
I print small parts on glass with Magigoo for better athesion.
I set the fans on the print head to 5%. This reduces warping, which is increased by the cooling of the part.
I work differently with large parts.
From a certain part size with a certain part volume, and when using 0.8 nozzles, the edges inevitably come loose during printing.
To improve adhesion, I use a mixture of 1/4 wood glue and 3/4 water.
A 1/10 mixture works just as well. The only difference is that the cross-linking on the printing plate is easier to observe and it holds very well.
With wood glue, which is the last resort for good athesion, I have to knock the parts off the plate with a hammer, so to speak.
That's why I print large PA parts on aluminium plates. Because the glass plates don't last long.
I have also used the Athesionssheets for this. But that had the effect that the sheet came off the printing plate.
At PA, many people, like me, have developed their own kung fu.
I am therefore curious to know if there are other ways.
