6 hours ago, TimonR said:…
We are still actively monitoring if we see issues coming up like this, and I can imagine transportation to specific sites with higher temperatures might indeed lead to brittle PVA. Did you report your experiences to our customer service? Can you also share (roughly) where you are located?
Oh yes, many conversations with Fbrc8, many posts in the community here. I was even given the fine knurl feeder kit, which I tried (and since reverted). I’m located in Massachusetts, USA, which is in the northeast part of the country, though I think my UM filament comes from a warehouse further south.
- 1
TimonR 21
@MobyDisk: that is true, especially in winter the moisture content in the air is relatively low, especially if you print in a room with heating.
To give you some insight: typical office environments have 50% RH at 20C in spring / autumn (summer can be a bit higher ~60%, and winter really depends on how cold it is outside).
Anyway, let's take 50% RH at 20C, if you heat up the same air with the same moisture content, your relative humidity will go down to only 10% RH. The point is that RH is kind of the 'active' moisture and this determines the moisture uptake of your filament (not the total gram water in air). So for getting wet filament and/or drying filament RH is the key parameter to focus on.
Increasing temperature helps in enhancing diffusion of moisture from within the filament to the air (basically speeding things up).
TimonR 21
@rachael7
Thanks for sharing your experience here.
To be honest, for us the brittle PVA in the Material Station was also unacceptable, we actually had a crash team working from multiple angles on this for several months - we definitely did not ignore this.
For the other readers, check here in case you're interested in what we've done: https://support.ultimaker.com/hc/en-us/articles/360015621060-PVA-material-breaking-in-the-Material-Station.
So indeed, the brittleness is improved directly at the production location, and we design a feeder wheel with finer knurls to not damage the PVA. Our coarse feeder wheels apparently create a starting point (craze) for brittleness.
TimonR 21
@Andrew_W: Thanks for the picture. I guess this is UM PVA and UM/3rd party black PLA?
What is your main issue and could you share a 3mf file?
