I have solved my problem. For anyone who may come across something similar:
In the design of my 3D object, some of the solid bodies had duplicated in place, so that 2 identical objects sat within each other. I would have thought that this wouldn't be such a problem, but going to my 3D object and deleting the duplicates solved my issue. I think this is an unusual symptom with a seemingly unrelated cause that I can't quite make sense of. Hopefully someone may find this post useful in the future
1
geojenks 1
No I can't upload images. Here are some external links to see them:
https://ibb.co/xX3RRfB
https://ibb.co/RStywt8
https://ibb.co/D1JN4SR
Essentially the problematic part of the STL is 7 solid bodies, 2 of them look perfectly fine on the preview tab of Cura, the other 5 are all missing every other layer, so one layer is present, but nothing is printed immediatley above, but the layer 2 above is fine. This means that when I print it, there is too much of a gap and the print doesn't come out ok.
This only happens after I group the print with the other part, before grouping, if I slice the model then it looks as if it will print every layer just fine
