should i try?what is your opinion
See the first comment in that thread; it has my opinion. Your printer wasn't made for 1.75mm. It will probably not break by trying to use it, but it may clog fairly badly. If you don't mind the risk and fixing a clog, sure, go ahead an try it. I would not recommend printing with 1.75mm unsupervised (eg overnight, or during the weekend).
11 hours ago, roshan_ultimaker said:the problem is one of the client is demanding his part in colour which is only available in 1.75mm filament diameter
From Colorfabb you can order any RAL color you like.
ahoeben 1,986
See this thread (including the replies):
