Try decreasing the value of the "skin removal width" setting
Ok wow, that WAS easy. lol Thanks Nallath.
That fixed the problem, but more importantly helped me understand part of how the top/bottom skins work. So while it did fix the problem, I thought the better option would be to adjust the emboss to 1.2mm which effectively did the same thing by increasing the skin width in the model itself.
nallath 1,123
JAZ013 1
Too easy. Thanks!
nallath 1,123
In case you didn't install it already, there is a super good plugin on the marketplace about the settings: https://marketplace.ultimaker.com/app/cura/plugins/Ghostkeeper/SettingsGuide2
JAZ013 1
No, I had not installed that. Instaled it and it's already been very helpful and informative. Thanks again!
