Thanks for your advice, actually the problem has reduced quite a bit.
In the photo you can see that there are some filaments left, which didn't actually cause any problems, removed with a lighter in seconds. I think increasing the retraction by a little should solve it, I don't want to lower the temperature too much. However, strange that in the Cura preview the shrinkage points in the media are not displayed.
GregValiant 1,492
"Max Comb Distance with No Retract" = 70. That means no retraction until a travel move is over 70mm and your part isn't that big. Try changing it to 2mm. I counted 1760 moves in the Z in the gcode sliced with your 70, and 7000 Z moves when changing that setting to 2mm. A Z move results from either a retraction, a prime, or when lifting to the next layer. I didn't actually go through the gcode and count retractions.
I don't like "Retract before outer wall" or "Retract at layer change". The resultant primes always seem blobby with my Ender. They have their uses but generally I avoid using either of those (or Z-hops) except in special circumstances.
