Well the workaround works (and is not all that complicated to perform), and the single click solution you seem to want does not exist. You can wait until a single click solution does exist, or use the workaround now.
GregValiant 701
I agree it should. But for myself I've found that 4 mouse clicks isn't that much more work than 3 mouse clicks if I take a short break between them.
It seems that the "Easy" button is still in Beta and probably will be for a while.
1
ahoeben 1,601
One way to do that is to save a project and load it back in. When asked if you want to update the current printer or create a new one, choose creating a new printer.
shanejoe 0
feel as though it should be easier then this work around
