it's happened every time I've completed a print over the last two weeks. I did just move the printer to a new location and had to remove/re-add it to digital factory once it got on the new network. I assume that confused something.
I would try to remove and re-add it again, maybe that solved the problem.
Smithy 1,088
I think you mean the Digital Factory where you see a wrong state?
It is not normal, but I guess that the printer has lost the connection to the DF for whatever reason.
Was it just one time or do you have the problem after every print?
