CURA - Difference in printing time
rabsystem
Posted · CURA - Difference in printing time
The differences are coming from the travel moves. Cura has some travel speeds defined for your printer and your printer itself has some limits in the firmware. So when Cura calculates the printing time, it is using the speeds you have defined in Cura. But when you printer limits these speeds or some of them, then it takes longer.
You can only find out what are the limits in your printers firmware and adjust the speeds in Cura.
        • 26 replies
