tinkergnome 929
34 minutes ago, DaveTheFace87 said:I have already used the mesh tool to split them but I still need them smaller.
Sounds like the opposite...?
You have already separated the individual models and now you want to split a single 3D model into several parts?
Like this: https://www.windowscentral.com/how-split-3d-model-3d-builder ?
GregValiant 1,492
A picture is worth a thousand words. A screenshot of Cura is worth 1,348 words.
You could scale them. You can move some off to the side of the build plate while you slice others. You could export the individual parts as their own separate STL files and load them later. Hard to tell without seeing what you are trying to accomplish.
