I left the printer clean and switched off. Neither moved nor any other mechanical issue.
I will try to open it to check all connections.
All connections are OK, dont know how to proceed... ???
Did you check the wire connection to the print head? I have add similar problems and invariably reseating that connection solves it. You have to undo the two bolts on the top of the print head to get at it.
Will do so. Thanks.
CarloK 190
There are no components in the UM3 that are affected by time, i.e. no batteries or such components.
Is it possible a connector came loose? Was the printer moved around during those 3 months?
