10 minutes ago, Smithy said:You cannot and don't need to calibrate the steps, they are fine.
If you don't get the expected dimensions, you are printing probably too fast or too hot. But there are some other settings as well to achieve better results.
Use for your tests the engineering profile and you will see that the result will be much better.
OK. I am going to test this profile. But I have only problem on ultimaker. On prusa, artillery, flashforge or COSMYX, no problem for dimension. All my parts can be assembled.
So for me calibration is not fine.
Smithy 1,088
