OK, thank you. I wait for the bugfix.
GregValiant 1,330
@tacotijsma The workaround is to set your Layer Height to something NOT equal to the thickness of the model then it will slice.
Example: If the model is 0.2mm thick then Layer Height = .199 it will allow it to slice.
That solves it. Thank you @GregValiant
nallath 1,124
Yep, this is a known issue. Objects lower than the initial layer height are not sliced.
