Sorry but that wasn't what I meant.
I meant that it wont let me print because it is saying I am printing a dual extruder. The only problem is I only want to print with one extruder and I dont know what settings to change for that. It says Filament run out when I want to print because it is set for dual extruder.
GregValiant 1,492
When I add a Lotmaxx SC10 to Cura it comes up as a single extruder printer and there is no option for a second extruder.
Load a calibration cube or a benchy in Cura and make your settings. Then under "File" use the "Save Project" command and save the project as a 3mf file. Post that 3mf file here and someone will take a look.
After you do that, open the 3mf file I attached below. It uses your printer and the model is a calibration cube. You can slice it and generate a gcode file. The speeds and acceleration numbers are conservative.
I'm also attaching a gcode file that I created from that project file. Copy it to your SD card and it should print.
edit: Make sure the cord for the "filament runout sensor" is plugged in at both ends. If you are confident that the filament is in contact with the sensor, and that it's wired correctly, then maybe it's a bad sensor. A LotMaxx support group may be able to help.
LotMaxxCalibration Cube.3mf LMCalibration Cube.gcode
Edited by GregValiantLink to post
