Walls print with standard print profiles but not my custom ones
TRMerc
Posted · Walls print with standard print profiles but not my custom ones
I set up some custom print profiles to reduce the distance between lines to create a more solid looking print as well as some special brim, infill, and temperature settings. However I have a model with a thin wall that when printing with the standard profile is 2 lines thick, but when I use my custom profile it does not slice.
    Posted (edited) · Walls print with standard print profiles but not my custom ones
    i think it might be caused by reducing distance between lines. Try to reset that one and see if it still doesn't slice.
    if you want to have smooother looking surface, for top layer you can choose ironing, for bottom layer you can change initial layer line width or initial layer flow to lets say 120% or whatever works
    i'm not a pro but hope this helps
    Edited by NomakeR
