Cura Slicing Behavior
bmullins3
Posted · Cura Slicing Behavior
Is there a way to keep Cura from trying to slice the current work piece until I have it positioned as I want it? I have opened a couple of fairly large .stl and .obj files and Cura insists upon slicing while I'm still trying to orient the piece in the work space. Some times I might want to print several pieces at the same time. It would be nice if I could get Cura to hold off on slicing until I'm through setting the work pieces up. Can I do that?
