GregValiant 1,488
If "Illusi" or "FieldOfView" would have seen it on Reddit they would have known right away. The problem with getting attention here is that it is an obvious Flsun problem rather than an Ultimaker Cura problem. There are oddities with the Creality Ender 5 and Ender 6 platforms as well.
GregValiant 1,488
If you open the printer definition file ("Ultimaker Cura 4.x.x\resources\definitions\Flsun_qq_s.def.json") in a text editor like Notepad you will see this:
"author": "Cataldo URSO & Eddy Emck ",
"manufacturer": "Flsun",
"platform": "flsun_qq_s.3mf"
So Flsun provided Ultimaker with the definition file as written by those authors. The "platform" is a file in the Cura "resources\meshes" folder. You can open that file in something like MS 3D Builder and rotate it the way it needs to go (which is not always the way you think it should go), and then export the file as another 3mf. Change the name of the original file so you have it as a backup and then change the name of the new file to "flsun_qq_s.3mf". Close and restart Cura. The platform will be in the new orientation.
If you get it right on the first try that's pretty amazing. You should probably check with an Flsun help site as well. Maybe there is a reason they made it that way.
Husar 0
This is very helpful. You are the first person between the FB group and Cura Reddit that has been able to answer this. The Flsun people are on the FB ground so now I know who to go after next. 😉. Thank you.
