Posted · Cura Speed Problem !
Hello there who read this topic
I need some help about an issue I recently happening to my Ultimaker Cura app, this is the subject: When I set the printing speed of the 3d model, I can´  t print speeds over 25mm/s even
when it is setting correctly, ..I made a simple test: one cube 50x50x10, spiralized, no bottom no top, printspeed and wall speed at (for example) 70mm/s.....!!!
the problem is Cura no longer give me that speeds.. just 20mm/s at any slize I make, even I set the speed at 120mm/s.. nothing happen,
I uninstaled, reinstaled and even tryed olders versions..
and it is just the slizer no the printer inself, my artillery respond correctly to the gcode ofcourse so the stimated time was right but... wt# !!  could be happening?!?
any help I will be graeful 🙏
