For undersize holes there is a feature in Cura called "Hole Horizontal Expansion" that works quite good, I typically just set to 0.4mm and this way you don't have to compensate in CAD.
1
gr5 2,234
You should be able to improve that with the "engineering" profiles. S5 should have some engineering profiles.
Also be aware that smaller printers will give you better tolerances (So S3 typically better than S5 and UM2go is even better).
