3 hours ago, Chris1982 said:
That's the Ultimaker Format Package file. When loaded into Cura it looks correct with the top surface being 12 layers thick. Without a project file there is no way to tell if there might be something else going on.
yes it shows many layers in the simulation. but it does not print the layers the simulation shows.
I made a new 3D model to check if the model was wrong but the same result again.
When I slice it the preview shows 20 top layers everywhere.
Open the Gcode or UFP file using Cura ( I think Cura will open a UFP but I'm not sure). A separate program reads the file and Cura itself has no idea of how it was sliced. So that preview of a gcode (or UFP) file will show you what should print.
I do have a program to read Gcode Files into AutoCad and completely remove Cura from the loop. It will not read a UFP file. I don't think my utility will be of any use in this case because you probably printed from that UFP file.
GregValiant 1,318
You will need to supply something for the folks here to analyze. Use "File | Save Project" and post the 3mf file here. Without something to look at any advice would be guesswork.
