Thanks for the info, I ended up reusing the UMO+ feeder motor with the UM2+ feeder assembly.
The UMO+ feeder motor is in the longer 24mm shaft length (the correct length should be ~16mm so the step file may be incorrect) so I put some M3 nuts as spacers on all four connecting screws to attach it to the custom UM2+ feeder mount https://www.youmagine.com/designs/um2-extrusion-upgrade-kit-mount-for-umo.
Edited by ansonl
tinkergnome 927
Yes, the shaft of the feeder motor is shorter on the UM2+ (if i remember right).
Anyways: i think you should look for the motor assembly (motor with on-pressed gear). The spur gear is not available as a separate genuine spare part (as far as i know - cheaper replicas are a different topic).
Ultimaker part number of the motor assembly is #9470
