Monster RepRap
ian
  • 2 weeks later...
Posted · Monster RepRap
Hi Jelly !
I wonder would it be more preactical to take a good model, split it into sections like a rubex cube.
Then with a farm of 5-8 ultimaker printers, run off each section and with a little glue, perfect.. finishes product.
Also there would be a lot more control, as when one piece failed, it could be easily reprinted.
With this one big wonder printer, one mistake and the whole thing can go in the bin ?
Ian :D
    Not to mention the printing speed, volume goes up with the cube of the length! They'd better use a massive nozzle for any performance at all...
    yes, bigger nozzle always helps:
