cura 4.12 crashes giving me this error when trying to view a sliced .STL
btketner1
Posted · cura 4.12 crashes giving me this error when trying to view a sliced .STL
Traceback (most recent call last):
File "C:\build\Cura\4.12-exe\build\inst\lib\python3.8\site-packages\UM\Qt\Bindings\MainWindow.py", line 255, in _render
File "C:\build\Cura\4.12-exe\build\inst\lib\python3.8\site-packages\UM\Qt\QtRenderer.py", line 163, in render
File "C:\Program Files\Ultimaker Cura 4.12.0\plugins\SimulationView\SimulationPass.py", line 65, in render
self._layer_shader.setUniformValue("u_active_extruder", float(max(0, self._extruder_manager.activeExtruderIndex)))
AttributeError: 'NoneType' object has no attribute 'setUniformValue'
Thread 0x00001100 (most recent call first):
File "C:\Program Files\Ultimaker Cura 4.12.0\plugins\USBPrinting\USBPrinterOutputDeviceManager.py", line 87 in _updateThread
File "threading.py", line 870 in run
File "threading.py", line 932 in _bootstrap_inner
File "threading.py", line 890 in _bootstrap
Thread 0x000018e4 (most recent call first):
File "threading.py", line 306 in wait
File "zeroconf\__init__.py", line 2534 in wait
File "zeroconf\__init__.py", line 1715 in run
Thread 0x00001070 (most recent call first):
File "threading.py", line 558 in wait
File "C:\Program Files\Ultimaker Cura 4.12.0\plugins\UM3NetworkPrinting\src\Network\ZeroConfClient.py", line 81 in _handleOnServiceChangedRequests
Thread 0x00000e80 (most recent call first):
File "zeroconf\__init__.py", line 1369 in run
Thread 0x0000065c (most recent call first):
File "C:\Program Files\Ultimaker Cura 4.12.0\plugins\RemovableDriveOutputDevice\RemovableDrivePlugin.py", line 61 in _updateThread
Thread 0x000012fc (most recent call first):
File "threading.py", line 302 in wait
File "threading.py", line 433 in acquire
File "C:\build\Cura\4.12-exe\build\inst\lib\python3.8\site-packages\UM\JobQueue.py", line 98 in _nextJob
File "C:\build\Cura\4.12-exe\build\inst\lib\python3.8\site-packages\UM\JobQueue.py", line 124 in run
Thread 0x000013e8 (most recent call first):
Current thread 0x0000150c (most recent call first):
File "C:\build\Cura\4.12-exe\build\inst\lib\python3.8\site-packages\cura\CrashHandler.py", line 396 in _logInfoWidget
File "C:\build\Cura\4.12-exe\build\inst\lib\python3.8\site-packages\cura\CrashHandler.py", line 182 in _createDialog
File "C:\build\Cura\4.12-exe\build\inst\lib\python3.8\site-packages\cura\CrashHandler.py", line 86 in __init__
File "C:\build\Cura\4.12-exe\build\inst\bin\cura_app.py", line 159 in exceptHook
File "C:\build\Cura\4.12-exe\build\inst\lib\python3.8\site-packages\cura\CrashHandler.py", line 452 in _show
File "C:\build\Cura\4.12-exe\build\inst\lib\python3.8\site-packages\UM\Event.py", line 218 in call
File "C:\build\Cura\4.12-exe\build\inst\lib\python3.8\site-packages\UM\Qt\QtApplication.py", line 479 in event
File "C:\build\Cura\4.12-exe\build\inst\lib\python3.8\site-packages\cura\CuraApplication.py", line 1094 in event
File "C:\build\Cura\4.12-exe\build\inst\lib\python3.8\site-packages\UM\Qt\QtApplication.py", line 393 in exec_
File "C:\build\Cura\4.12-exe\build\inst\lib\python3.8\site-packages\cura\CuraApplication.py", line 871 in run
File "C:\build\Cura\4.12-exe\build\inst\bin\cura_app.py", line 233 in <module>
File "Console.py", line 36 in run
File "__startup__.py", line 74 in run
    Yes Sir! Thank you! Fixed both 4.11.0 and 4.12.0
    The fix will be included in Cura 4.13
