It looks like you have the x-ray view enabled in preview and not layerview.
There is nothing weird going on in your logs, so the layerview should work.
6 hours ago, nallath said:There is nothing weird going on in your logs, so the layerview should work.
Ahem...
2021-11-17 12:35:50,913 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [426]: Plugin [SimulationView] has been disabled. Skip loading it.
@Rock-princess, you have managed to disable the plugin that is responsible for showing the sliced view. Go to the "Installed" tab in the Marketplace, and make sure the checkmark in front of Simulation View is checked.
1
20 hours ago, ahoeben said:
Ahem...
WOW just wow..
I'm such a clutch. your a life saver , sorry for wasting your time .. and thanks
ill buy you a beer if your ever around these parts
On 11/17/2021 at 11:00 PM, ahoeben said:
Ahem...
Whoops. My baaad! 😞
nallath 1,125
Could you post the entire log? The parts that you selected don't contain enough info to help you.
