Can't view Sliced view (windows 11)
Rock-princess
Posted (edited) · Can't view Sliced view (windows 11)
Hi I'm struggling to see the sliced layer view.
I prepared the model and I sliced it.
when hitting preview i only have x-ray mode.
I'm running the Final build of Windows 11
what I tried.
  1.  going to Preferences  > General > enabling Force Layer view Compatibility mode (then restarted) it disables the checkmark
  2. Going to Nvidia settings panel > Manage 3D settings >Program settings (tab) > adding  Cura -> specifying setting > OpenGL option setting it to Geforce GTX 2070
what I see when previewing
 1319865136_2021-11-1712_23_17-CE5P_base-UltimakerCura.thumb.png.d918343a49eae30bf4eb50079539f2d7.png
The Log file
Quote
2021-11-02 20:20:10,133 - DEBUG - [MainThread] UM.Qt.QtRenderer._initialize [210]: Support for Vertex Array Objects: True
2021-11-02 20:20:10,143 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [112]: Initialized OpenGL subsystems.
2021-11-02 20:20:10,145 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [113]: OpenGL Version:  4.1.0 NVIDIA 471.51
2021-11-02 20:20:10,147 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [114]: OpenGL Vendor:   NVIDIA Corporation
2021-11-02 20:20:10,149 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [115]: OpenGL Renderer: NVIDIA GeForce RTX 2070 with Max-Q Design/PCIe/SSE2
2021-11-02 20:20:10,151 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [116]: GLSL Version:    4.0.0
2021-11-02 20:20:10,154 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.11.0\resources\shaders\default.shader]...
2021-11-02 20:20:10,158 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.11.0\resources\shaders\selection.shader]...
2021-11-02 20:20:10,162 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.11.0\resources\shaders\select_face.shader]...
2021-11-02 20:20:10,165 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.11.0\resources\shaders\default.shader]...
2021-11-02 20:20:10,168 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.11.0\resources\shaders\composite.shader]...
2021-11-02 20:20:10,171 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.11.0\resources\shaders\overhang.shader]...
2021-11-02 20:20:10,175 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.11.0\resources\shaders\striped.shader]...
2021-11-02 20:20:10,180 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.11.0\resources\shaders\transparent_object.shader]...
2021-11-02 20:20:10,185 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.11.0\resources\shaders\striped.shader]...
2021-11-02 20:20:10,189 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.11.0\resources\shaders\xray.shader]...
2021-11-02 20:20:10,193 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.11.0\resources\shaders\xray_composite.shader]...
2021-11-02 20:20:10,198 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.11.0\resources\shaders\default.shader]...
2021-11-02 20:20:10,200 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.11.0\resources\shaders\grid.shader]...
2021-11-02 20:20:10,203 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.11.0\resources\shaders\platform.shader]...
2021-11-02 20:20:10,210 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.11.0\resources\shaders\xray.shader]...
Edited by Rock-princess
    Posted · Can't view Sliced view (windows 11)
    6 hours ago, nallath said:
    There is nothing weird going on in your logs, so the layerview should work.
    Ahem...
    2021-11-17 12:35:50,913 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [426]: Plugin [SimulationView] has been disabled. Skip loading it.
    @Rock-princess, you have managed to disable the plugin that is responsible for showing the sliced view. Go to the "Installed" tab in the Marketplace, and make sure the checkmark in front of Simulation View is checked.
    20 hours ago, ahoeben said:
    Ahem...
    WOW just wow..
    I'm such a clutch. your a life saver , sorry for wasting your time .. and thanks
    ill buy you a beer if your ever around these parts
    On 11/17/2021 at 11:00 PM, ahoeben said:
    Ahem...
    Whoops. My baaad! 😞
