Sorry, after the last power up I wrote "Still Nothing..." but the screen did actually come back on.
I just meant the printer was still unresponsive to new jobs.
I left the printer off (and IEC unplugged) since last night.
I just turned it on and have the "Print Failed. Please remove..." screen (That's different)
Gave it one more try to print a file from the flash drive. No luck.
Sending you the logs....
Thanks for taking a look.
CarloK 190
This is weird, you describe different types of problems that I've never seen before in this combination.
First try to get your printer to display again by running the recovery process described in this thread.
Then, when you run into printing problems again, could you dump the log files to usb and send them to me in a private message (click my avatar and on top of my pesonal screen is a 'message' button). Dumping the log files can be found in the system/diagnostics menu.
