Thank you, understood. I'd not tried 'Post Processing' as I'd wrongly assumed that was irrelevant to pausing during a print.
I'm still at the novice stage so... While using Cura's excellent Preview mode, how can I determine the layer ('height') that I should use for ''Pause at height' please?
For background, I will be trying to print white text on a black base. To postpone studying the obscure art of g-code, marlin, etc I'd like to try simply using the Pause button. So need to know roughly when to be poised to do that.
CarloK 204
Cura does have this functionality since ancient times...
Cura menu Extensions / Post Processing / Modify G-code. Click 'Add a script' and then select the 'Pause at height' script.
One known caveat though, the current UM2+C printer v1.5 firmware doesn't support this feature yet, this will come in a future release.
