Thanks, I think I follow this reasoning. I was concerned that these values would override any of the same ones in my global settings, and would be tedious to have to copy the same values here as well. As I understand it, these values are to prevent unnecessary walls and top/bottom layers being created, and is a good thing! I'll try a print with and without and see if I can see the difference.
I wasn't aware this was hard-coded into the main executable. I had previously added a plugin/addon (to do with cylindrical supports) which appeared at the bottom of this menu, leading me to believe it was modular and editable.
ahoeben 2,047
There isn't really a way to do this. The "pre-selected" settings are fairly hardcoded into Cura.
Those default settings, which only appear when you select the "infill mesh only" option, make that option behave more like you would expect them. If you remove them, you get extra walls at the edges where the mesh intersects the main mesh. With these settings, you really only affect the infill.
