2 hours ago, ahoeben said:This is how cutting meshes work. Cura can not apply settings to a part of a model only, so internally it has to cut the model into parts.
One way to get much closer to what you want is to not use a support blocker cube, but load a custom piece of geometry that is modeled to overlap on precise areas only.
So for example if you had a cylinder object where you only want a section in the middle to be fuzzy, you could model a "sock" tube as it were that has an inner diameter that is a fraction smaller than the outer diameter of the cylinder. Then use that as a cutting mesh.
Got it, it is a solution I was thinking about too, but it will change and partially mess up the mesh anyway.
I've got no experience with other slicers, but I wonder if this is the same method that Prusa or Ideamaker's softwares use to locally apply textures or generate fuzzy skin. Don't think so. If there is no other way to do it in Cura, I think Cura should create it.
Edited by centunesima
ahoeben 1,721
