And also these switch plates, need some cleaning from time to time. It depends on your brand, some needs a wipe with alcohol, others needs to be refreshed with some fine sanding paper.
If you have some finger grease in this spot it could also decrease the adhesion.
Smithy 1,132
For me it is strange that you need a Z-offset of 0.15 and could cause the problem you see. With such an offset you get automatically a lower bed adhesion.
You plate, is it a Filafarm switch plate? I am using one on my S3 and have no problems with it and don't need to set a Z-offset for it.
But it could be, that you plate with the coating is not 100% flat. With a bed size of an S5 it is hard for such tools to get a flat surface over the whole area. So I would test it with the original setup, glass with a some PVA glue and see if is better.
