Aliexpress.com filament??
LarsU
 Share
Posted · Aliexpress.com filament??
(translate)
Is it possible to order print filament on aliexpress.com .
PS. 2.85mm (I print with the ultimaker original)
Β
πŸ™‚πŸ™ƒ
Β
Is het mogelijk om print filament te bestellen op aliexpress.com .
PS. 2,85mm (ik print met de ultimaker original)
    You need a credit card or AliPay.
    Easier in Euopa is ordering via Ebay. The material quality is notoriously bad.
    But everyone goes through this phase.
    Significant quality defects (In my case, 5 years ago, it was)
    - Different diameters cause problems when printing.
    - Material partially overlaid and brittle.
    - Material changes color during printing. Or sometimes loses the color and becomes transparent.
    - I have also had material end in the middle of the roll.
    - Clogged nozzles
    - And the material is often very smelly.
    You can learn a lot from it. If sometimes also not to print, but over itself and its patience.
    Many greetings
    Posted (edited) · Aliexpress.com filament??
    Hi @LarsU,
    Β
    In general you can print any compatibleΒ 2.85mm material. However there is a few things to be aware of:
    • There can be a difference in quality depending on where you get your filament. For example; The tolerance on filament diameter might be slightly off, or varying more than you'd expect. This could lead to some visual defects, like small under or over extrusion in the print. Also sometimes off-brand filament contain debris that can cause your nozzle to clog.
    • Some filaments absorb moisture quite fast, depending on how (long) the material was stored, you might want to dry it before use.
    • Some filaments might (secretly) be a blend of different materials, so when you think you are getting PLA, there could be a high content of ABS in it. While this in itself is not necessarily a problem, keep in mind that not all filaments are pleasant / recommended to print without air manager.
    • It might be that the default print profiles are sub-optimal for the specific material you chose to use.
    I am not trying to discourage you, it is definitely possible to print non Ultimaker materials. And its not like they are all bad, there are probably some great alternatives out there.
    Β
    Jos
    Β
    Edited by Josnoww
    I can also recommend this for Ultimaker filament. Especially with PA, PC and PVA from Ultimaker I already had problems. Depending on the dealer, the filaments are sold less frequently and thus stored for a long time.
    Β
    Good to see what else there is so all:Β  https://marketplace.ultimaker.com/app/cura/materials
    Β
    If you are looking for alternatives, it is best to use a brand name. Very cheap but still good filament brands are Anycubic, eSun or Verbatim.
    Β
    • AliExpress is unfortunately a kind of extreme.
    • Ultimaker filament, is expensive but easy, good and safe to use with Ultimaker printers.
    • Other brands require a bit more experience for the first prints.
    Many greetings
     Share
        Β
        Β
        Β
        Β
        Β
        Β
        Reliable bed tilt compensation (no more thumbscrews) 2.4 and 5 GHz Wi-Fi A 1080p camera (mounted higher for a better view) Compatibility with 280+ Marketplace materials Compatibility with S5 project files (no reslicing needed) And a whole lot more Β
        • 13 replies
      • UltiMaker Cura 5.3.0-Alpha πŸŽ„ Tree Support Spotlight πŸŽ„
        Β
        We generated a special version of Cura 5.2 called 5.3.0 Alpha + Xmas. The only changes we introduced compared to UltiMaker Cura 5.2.1 are those which are needed for the new supports. So keep in mind, this is not a sneak peek for Cura 5.3 (there are some really cool new features coming up) but a spotlight release highlighting this new version of tree supports. Β
        • 17 replies
      • New here? Get ahead with a free onboarding course
        Β
        Ultimaker S5 Pro Bundle, Ultimaker S5, Ultimaker S3 Ultimaker 2+ Connect.Β  Β
        They're ready for you on the Ultimaker Academy platform. All you need to do to gain access is to register your product to gain free access.Β
        • 14 replies
